Laptop liga e desliga
O meu Laptop, ao ser ligado, arranca e depois sem sequer mostrar imagem alguma (com a tela escura), desliga por si
Esta é uma boa pergunta?
@alfredotxizanda let us know what exact model your laptop is. After that, follow some common procedures.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged and it may be that your computer runs out of power if there are issues with the AC adapter.
There is also possible that this is a bad RAM module or a bad LCD. Remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Finally, if you are running windows, access the Event Viewer and see what it shows. Let us know what you find out
Translation
@alfredotxizanda diga-nos qual é o modelo exato do seu computador portátil. Depois disso, siga alguns procedimentos comuns.
Comece com as coisas mais fáceis. Desligue a alimentação do computador, desconectando o cabo de alimentação do computador. Desligue todos os dispositivos externos do computador. Retire a bateria Agora mantenha o botão de alimentação premido durante cerca de 30 segundos a 1 minuto. Volte a ligar o adaptador de corrente alterna e verifique se o computador apresenta algum sinal de vida.
Em primeiro lugar, é necessário verificar a fonte de alimentação. Certifique-se de que tem as tensões correctas. Verifique se os conectores não estão dobrados, etc. Depois disso, verifique a porta de carregamento. Limpe-a de quaisquer detritos, etc. Utilize algumas baforadas de ar para a limpar. Verifique a tomada de entrada DC do seu computador portátil. Certifique-se de que não há corrosão, detritos, etc. que a impeçam de funcionar.
Naturalmente, poderá também ter de considerar a substituição da bateria. Uma bateria descarregada já não pode ser carregada e pode acontecer que o computador fique sem energia se houver problemas com o adaptador CA.
Também é possível que se trate de um módulo de RAM ou de um LCD danificado. Retire a RAM e limpe os contactos com uma borracha de lápis. Faça-o com cuidado para não destruir o módulo. Volte a colocá-lo no lugar e reinicie. Se tiver mais do que um módulo, retire-o e deixe apenas um ligado.
Por fim, se estiver a executar o Windows, aceda ao Visualizador de Eventos e veja o que este mostra. Informe-nos do que descobrir
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 18
