Ir para o conteúdo principal
Is this battery compatible with the 455 g1 laptop?
Compatible with the probook 455 g1 laptop also?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Doesn't seem to be.
G1 battery
and
G2 battery
Different shape.
Esta resposta foi útil?
Pontuação 1
Hi @jeffreyhol86712
I would say that they're not compatible.
Here are the HP part numbers for the batteries compatible with each model.
As you can see they're different. Manufacturer's tend to to use the same parts across different models if they were compatible as it saves on costs.
ProBook 455 G2 Battery - see p.36 of the 455 G2 maintenance and service guide
4-cell, 44 WHr, 3.0 Ah Li-ion battery 756744-001
4-cell, 40 WHr, 3.0 Ah Li-ion battery 756746-001
ProBook 455 G1 Battery - see p.38 of the 455 G1 maintenance and service guide
9-cell, 93 WHr, 2.8 Ah Li-ion battery 708458-001
6-cell, 47 WHr, 2.2 Ah Li-ion battery 708457-001
Search online using the part number only, to find battery suppliers that suit you best.
Pontuação 1
Adicionar a sua resposta
Jeffrey Hollingsworth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 212
