Ir para o conteúdo principal
O Bose QuietComfort 35 II (número do modelo: 789564-0020) é um fone de ouvido Bluetooth com cancelamento de ruído projetado pela Bose. O dispositivo vem com um carregador USB e um cabo com entrada para fone de ouvido, sendo compatível com dispositivos Bluetooth iOS e Android.
Charging problem - replace Micro-USB connector?
I can't charge the headphones. Is it possible to replace the Micro-USB connection?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
I also have this issue.
With the charger disconnected I see a blue led light of the pairing that is always on.
When I connected the charger to the micro USB connector a red led light starts flashing and the blue led light continues to be on.
I already replaced the battery. I was now thinking on replacing the micro USB connector. Do you have any other idea's?
por Compartilhar
If you have 2 LEDs, the blue one is telling you it is on and paired. The blinking red one is telling you it is charging. If there was a problem with the connector, the red LED would not be flashing when you plug it in. However, if it is "flashing' (fast blinking) it may be telling you there is a problem with the battery or something internal.
por Compartilhar
Adicionar um comentário
1 resposta
Why do you think it is the connector? There are a number of other possibilities including the charger and the battery.
Post any symptoms you have experienced in the past.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have several chargers.
The problem occurred suddenly without deteriorating battery before.
I can visually see the damaged connector.
por Compartilhar
Adicionar a sua resposta
Johan Varland será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 621
