Ir para o conteúdo principal
An Acer Aspire 5100 Laptop with a 15.4" inch display.
For some reason it is not charging whatsoever?
how would i find out whats wrong with it and acces where the charging port is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Of course, make sure your AC adapter is working properly, and that you have a good battery. Make sure all your connections are clean and properly aligned. I f any of this is okay, you will have to dis-assemble your computer. Follow this guide. In the last picture, you will see the DC connector. Unsolder the old one, and replace it with one of these Here you can see what it looks like. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Leo Draper será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,178
