Ir para o conteúdo principal
Lançada em abril de 2014; identificada pelo modelo ILCE-6000. Uma câmera digital mirrorless com montagem tipo E e sensor de imagem APS-C.
Camera LCD screen is not working.
The camera powers on but only shows a black image with slight green tint when any lens is attached. All setting displays still appear on the screen. Does anyone know why?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Have you tried to take a photo with your camera and then viewing it on your PC? Are the photos also black as you say in your question?
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @officialxgeorge
Seems as though there's a lens sensor (faulty cmos sensor, loose connection?) or a motherboard problem. (supplier example only to show part)
Seeing the menu options on the LCD display, proves that the display is still working and also the motherboard, to a degree anyway.
You can prove if the sensor is faulty by taking some pictures (I realize that you can't see what you're taking), and then downloading them to a computer. If there are only black images then the sensor is faulty and hopefully the motherboard is OK given that you can do all this.
Here's the ifixit Sony α6000 guide that may help.
Esta resposta foi útil?
Pontuação 1
2 comentários:
@jayeff Let’s say that the lens sensor is broken. Will it be worth it to fix it? Or should I just look into getting a new camera? I’ll give an update when I get the chance to connect it to a computer.
por Compartilhar
@officialxgeorge
You may be able to find cheaper sensors that I did but most I found were around about that price or more.
Depends on how much you like the camera I suppose.
Your choice.
por Compartilhar
Adicionar a sua resposta
George será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 302
