What capacitor is this?
This is a photo of another board but on the board i am working on, the capacitor is leaking and needs to be changed. I am not sure what the capacitor is, does someone know what capacitor it is?
Esta é uma boa pergunta?
@choukosenpai does not look like a capacitor at all. That looks like a coil. If you can post a bigger picture so we can see whatever it is that is printed on it, I am sure we can identify this component.
Thank you for adding the image to your Question. Like I suspected it is a coil. In this case it is a 3.3uH inductor. Now the only thing you have left is to measure the physical dimensions (width and length) This will be an easy part to source. Fairly straight forward repair too. What Country are you in (no details please) so we can try and find a supplier.
Esta resposta foi útil?
i have added a new picture, the thing is that i cant get a close up of the component since the leakage of the component has removed the text ontop of it, that is why i said that it is another photo of the board (i have taken this photo from google)
this is the closes schematic that i have found
@choukosenpai Ok let me look at this in a few hours. I am at a place right now that does not allow me to look at it. :-)
@oldturkey03 alright thank you,
@choukosenpai it's identified :-)
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 133
3 comentários
@choukosenpai you do want to go ahead and post a larger picture so we can at least try to help you with to much eye strain :-)
What board number is this?
por oldturkey03
it is a SPCH- 77004 board, i would post a clearer photo of the component though the leakage of the component has removed the text ontop of the component. hopefully it helps
por Mr_Chou
@oldturkey03 this is the closes schematic that i have found
https://gamesx.com/wiki/lib/exe/fetch.ph...
por Mr_Chou
