Ir para o conteúdo principal
Repair and disassembly information for Samsung's flagship S20+ Android smartphone, released in March of 2020.
Esim why? Esim It does not have a device
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I'm sorry, but I don't understand your question. Do you mean why your Samsung Galaxy S20+ does not have an eSIM? If so, the answer may depend on where you bought your device and which carrier you use.
According to the information I found, the Samsung Galaxy S20+ has an eSIM when purchased from participating retailers and operators around the world¹. It can be activated with an eSIM plan from participating mobile network providers in your area, or from eSIM.net¹. However, the eSIM availability and functionality may vary depending on country, carrier, and model¹.
An eSIM is a small electronic chip inside a phone that serves the same function as the small plastic SIM cards we've used for years³. It can give you some benefits, such as being able to switch between carriers easily, having two phone numbers on one phone, and saving space inside your phone³.
I hope this helps you understand more about the Samsung Galaxy S20+ and eSIM. If you have any other questions, feel free to ask me. 😊
por
Adicionar um comentário
1 resposta
@abushluiz maybe you forgot to activate your eSim. Go to navigate to Settings > Connections > SIM card manager and here you do select your providers mobile plan. If you have a QR code from your service provider, scan it to complete the process.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Abush luiz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 141
