Ir para o conteúdo principal
O Samsung Galaxy A10s é um smartphone Android desenvolvido pela Samsung Electronics e lançado em março de 2019.
My camera is not working
My camera app isn't open and my phone says camera isn't connected
Esta é uma boa pergunta?
Pontuação 5
3 comentários
My phone camera is not working
por
Camera did not
connected problem
por
My samsung a10s the camera is not the
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Some time camera could not connected
Esta resposta foi útil?
Pontuação 1
1 comentário:
Camera still not working after all steps attempt.
por
I’m sorry to hear that your camera app isn’t opening and your phone says camera isn’t connected. This could be due to various reasons, such as a faulty camera module, a corrupted camera app, or a software glitch. Here are some possible solutions that you can try:
  • You can reset the camera app by following these steps1:
    • Open Camera and select Settings.
    • Select Reset settings.
    • Tap Reset to reset the Camera app.
  • You can check for any updates for the camera app or your device’s software by following these steps2:
    • Open Settings and select Software update.
    • Tap Download and install to check for any updates.
    • If there are any updates available, follow the on-screen instructions to install them.
  • You can reboot your phone into Safe Mode and test the camera app by following these steps3:
    • Hold down the power button until the Power menu pops up.
    • Tap and hold the Power off button.
    • Tap “Safe mode.”
    • Test the Camera once it reboots in Safe mode.
    • If it’s working fine, a third-party app may be causing the problem. You can uninstall any suspicious apps or disable them in Settings > Apps.
  • You can watch some videos that show how to fix the camera not connected problem on Samsung A10s. For example, you can check out these videos: Samsung A10s Camera Not Working Problem Solved . They demonstrate how to use a multimeter and a soldering iron to repair the camera module and restore the connection.
I hope this helps you fix your Samsung Galaxy A10 camera not connected problem. If you have any other questions, please feel free to ask me. 😊
Pontuação 0
Adicionar a sua resposta
Amar Mohammed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 23
Ao todo: 1,279
