White screen with cursor
When opening Laptop showing white screen with cursor
Esta é uma boa pergunta?
@sanjanarachappa connect an external monitor to your Ideapad via the HDMI port and let su know if that showed anything different. You also want to try to get into the BIOS of your Ideapad before it tries to stat the OS and see if that shows properly. Try to change the Boot order and see if you can boot from an external boot disk.
This could be an issue with the GPU, the OS, as well as multiple other issues. You got to start narrowing it down
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 11
