Ir para o conteúdo principal
O Razer Blade Stealth é um notebook gamer com tela de 13,3 polegadas. O laptop possui 16 GB de RAM e um processador Intel Core i7. Ele está disponível nas cores Cinza Espacial e Branco Mercúrio.
add or replace RAM
i would like to change out my ram. or add another memory module if possible. what ram does the computer use?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
First, I would want to know for sure which model you have (there are a lot of devices at iFixit, but there are so many Windows laptops it would be hard to have device pages for all of them).
But assuming you have categorized this correctly (and based on my experience with other Razer laptops), the RAM is not upgradeable. It is soldered directly to the motherboard. I would wager these are the RAM chips on the board. Occasionally a slot shows up on the back of laptop boards, but that is more often for a second SSD than RAM unless it's a beefy enough system that it can accommodate 4 RAM sticks.
Imagem
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
JJ Amaro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 41
Ao todo: 718
