Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
Spilled tea on my MacBook.
Question- I had the same thing happen to me about 12 hours ago and now the computer won’t turn on.
I dried it off but couldn’t open it up.
What is the tool needed to remove the back of the MacBoook? And where do you purchase it?
And if I can’t fix this myself, where can I take it?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@cissa You'll need a Pentalobe size P5 screwdriver to remove the back of the MacBook. You can get them right here at iFixit's store Most toolkits include a P5 driver. But you can find them around elsewhere now that you know what you're looking for.
As for where to take it if you can't fix it, that depends on you. Most places will have a local shop that can at least take a look and give an assessment. I would start there.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks. I’ll see what I find out checking references from this thread.
If I end up needing to take it somewhere (not the Apple Store- quoted $1k+), does anyone know of someone in the DMV area, that is, if I’m allowed to ask here?
por
Pergunta mais útil
First, remove and clean the logic board using 95%+ isopropyl (if there is any visible liquid on the board).
After this has dried, reassemble and try turning it on. If it doesn't boot, try plugging in the charger without the keyboard connected, since this can prevent booting. If it is still not working, try plugging the charger in without anything (except the essentials, fan, charger port, etc) plugged in. If it is still not working, the fault will be with the logic board.
Replacement boards are expensive, so take it to someone to repair if this is the case (or repair it yourself, if you have the equipment).
EDIT: Good it's all working. The issue will be related to the battery if it is only working on charge, and it had corrosion on the battery PCB.
You need to use a large flat tool (painting knife for example), dip it in isopropyl, and slide it under the battery carefully, to loosen it. You will need to remove the board and speakers to get the angle, and do not accidentally cut the trackpad cable or keyboard cable. If you are not confident in being able to do this safely, either live with the issue or send it to a repair company.
Also, be careful not to puncture the battery, bad things will happen D:
Pontuação 8
4 comentários:
Do I need to remove the batteries too? Or open the back case and clean up the logic board only? Because I couldn't find a good enough tutorial on replacing/tearing apart the keyboard.
(Not an engineer, just helping my mother out. Repair was quoted at $300. Mom thought I should take a shot at it.)
por
You just need to unplug the components, not remove them. This will help you isolate the issue to the logic board or a component. You access the Mac from the bottom (not by disassembling the keyboard like most laptops), and can find a guide here MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
por
You need to follow the guide posted by @reecee to remove the board from the housing/computer, clean it ASAP with 99% IPA & a soft tooth brush. There are no shortcuts if you wish to have a fighting chance. Sugar is highly corrosive. But I would do something opposite, as in start with the bare minimum, then plug in components. Turn off between trials. Always disconnect battery first & reconnect it last as you want to avoid shorting anything.
Start with power cord, fan. If you have led starting green then orange, and eventually a fan spin, disconnect, connect battery, try again. Then keyboard.
Usually keyboard and track pad are hit the most. Sometimes also the battery, if this model has a small board, inspect it. It may be covered with black tape/insulation. Be careful peeling stuff off.
The keyboard is a big pain to remove. You want to do it only if you are sure it is bad.
Finally, IMO $300 is not expensive if they use a pro ultrasonic cleaner to clean the board, k/b is included, and the people are real pros.
por
check the battery for signs of damage , hot liquids can cause the battery to swell . if the battery itself is leaking or swollen replace it . This guide is helpful
Electronics Water Damage
por
Adicionar a sua resposta
C.Issa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 44
Duração total: 105
