Ir para o conteúdo principal
How to assemble Learning Resources calculator
So I have this Learning Resources brand calculator, and I've been tasked on how to fix it. Any ideas? Here's some images of it:
Imagem
Imagem
Imagem
Imagem
A number on the back reads "B2393080208" and as seen in the last image, it has this solar power chip with the text "VIMUN" and the model number "SC-25100S".
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It's a little hard to tell from the photos, but looks like the display was ripped off. You won't be able to fix it unless you can solder and are able to solder the ribbon cable back on.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
QwertyULTRA2023 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 341
