How to Realign Gears on my Saeco Vienna Plus?
My gears are misaligned on my Saeco Vienna Plus and I can not get the brew unit to snap back in to place. How do I realign?
Esta é uma boa pergunta?
So try, If the motor works, use the test mode as explained here:
https://youtu.be/Ng-zQurYhXA?si=lDLFR-2k...
and here:
https://mschausprojects.blogspot.com/202...
Using the test mode the gears can be turned to the correct position. If not, a gear might be broken and you have to open the gear drive.
Esta resposta foi útil?
Thank you so much! That did fix it!
Push the switch that is behind the assembly upper middle side and the other switch that is on the left upper side that the door clicks it. Turn the machine on and it will synchronize the gears.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 34
Duração total: 246
1 comentário
@vauweh what do you think about this? any chance you could help @kimmhammar out on this one? ;-)
por oldturkey03
