Why am I getting code 9c8?
In the middle of spinning it started sounding ding and had code 9c8. I’ve already done update about fire recall. What now?
Esta é uma boa pergunta?
It's a software update issue.
Press and hold the start button to clear the error code. then hold the Smart Control button for 3 seconds and then the temp button for 7 seconds. Then turn the machine off and back on.
Esta resposta foi útil?
That did not work
That did not work. I soregret buying this washer, is a junk
Did not fix issue
@brendamay70158 same make and model? What are the issues? What all have you tried?
I cannot find the smart control button.
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 4,992
2 comentários
Way am getting a code 9c8
por kenny bruce Compartilhar
@kennybruce25022 9C8 - Software Overcurrent Error which appears to be frmware related. It is also possible that this is a hardware defect with the main control board or motor
por oldturkey03 Compartilhar
