Ir para o conteúdo principal
Laptop power button is damaged
When I press my power button the laptop automatically start powering on and off several times and after some time it stops. If I remove the cable of the power button then this stops happening. I think my power button somehow got ultra sensitive. Sometimes it just powers on the laptop when I barely touch it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you remove the cable how do you turn it on? OR do you remove it when it is on?
Without more specifics, it sounds like a bad switch. These switches are not mechanical, so it is likely worn or has been contaminated by dirt or a liquid.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Muhammad Usman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 195
