Ir para o conteúdo principal
Especificações semelhantes às do Dell OptiPlex 7010.
My PC Is Not Turning On Orange Light(Read Full Description))
My PC Shows An Orange Light I Have Changed The CMOS battery and Also power supply and also Ram but it does not turn on plz help me with this problem
Update (09/17/23)
thats issue
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @muhammadab87909
Is the amber light blinking or on steady?
Here's a link that shows what the problem may be depending on what the amber light is doing.
Find the section on the page entitled Diagnostic LEDs for the OptiPlex series (2012 to 2020) and click on the Power button LED link and the Diagnostic Indicator table link in that section
Esta resposta foi útil?
Pontuação 1
6 comentários:
It remains steady for a while and then it starts blinking
por
@muhammadab87909
Is there a pattern to the blinking e.g. 2 blinks > small pause > 1 blink > small pause > 2 blinks > small pause > or perhaps 3 blinks > small pause > 1 blink > small pause > 3 blinks > small pause > 1 blink etc
Check the Diagnostic Indicator table to see if there's a pattern mentioned that matches what is happening with the amber light.
Be sure that it is under the Diagnostic LEDs for the OptiPlex series (2012 to 2020) section as this is the one relevant to your model.
por
It goes like 2 blinks and 1 blink
por
@muhammadab87909
This indicates a problem is on the motherboard
According to the indicator table:
two blinks followed by a short pause, one blink, long pause, then repeats. Bad Motherboard Replace the motherboard.
Maybe check for any obvious component damage on the motherboard e.g. burnt out or bulging components.
por
Is there anything that I can do at home without repair because I have no money
por
Exibir mais 1 comentário
you should try the troubleshoot method that is to take the cable that is coming out of the power supply
unplug it , than wait a few seconds and than plug it again.
Pontuação 0
Adicionar a sua resposta
Muhammad Abdullah Gaming será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 34
Ao todo: 1,484
