Ir para o conteúdo principal
Informações de reparo e desmontagem para o Pixel Fold, o primeiro smartphone dobrável do Google. Lançado em 27 de junho de 2023.
Where can I get camera glass replacement
I woke this morning to find a hole perfectly above my camera so that the lens is exposed the camera still works except blurry between 2x-5x so my question has two parts first will the blue go away with a new camera glass and where can I get the glass? Thanks in advance
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I couldn't find OEM replacement glass but I did find tempered glass lens protectors.
https://www.amazon.com/dp/B0C5R3WFN6?ref...
I then followed the Pixel 7 Pro camera glass replacement. Glue released very easily with rubbing alcohol. I used masking tape to pull any loose shards off throughout the procedure. Used small spurts of canned air to clean everything out once the glass was removed. Turned out pretty good and have no loss of function.
https://www.youtube.com/watch?v=Y1WYIia-...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Steven Keck será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 1,431
