Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
My washer makes a noice and leaks from underneath
I have a stackable washer and dryer and it makes noise and leaks from underneath.
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Please give us the make and model number, also what kind of noise is it making?
por
There is a water pump on the bottom. Has serval hoses and a impeller. Its also plastic. You could have very several different scenarios going on. Client might come loose hose. My sucked up a sock and got your empire jacked up. Unfortunately you're going to have to flip it over on his back and get to the very bottom.
por
Make GE
Model GTUP270G M1WM
por
@mayer
Make-GE
Model- GTUP270G M1WM
por
Adicionar um comentário
1 resposta
Make-GE
Model-GTUP270G M1WM
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Maritza será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 55
