Ir para o conteúdo principal
O smartphone topo de linha da Samsung, o Galaxy S8. Lançado em abril de 2017.
My phone won't charge
Just changed my phone screen, and trying to charge it lately, it tells me charging stopped, your phone Temperature is too low, charging will continue when your phone Temperature returns to normal..
Why and how can I fix this, Samsung s8...
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@tallest1 there are a couple of reasons why your S8 may do this. Most common one is a bad battery. I would start with that one. OF course, a bad charging port or charging cable can also do this. Also make sure that the NFC and wireless charging item are properly connected to the board since that can give you the error message as well. It could have been disconnected while you were working on your phone.
Troca da Bateria - Samsung Galaxy S8
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tallest1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 246
