Ir para o conteúdo principal
My videocon ac showing e5 error
Some time My videocon ac showing e5 error
Esta é uma boa pergunta?
Pontuação 0
1 comentário
code L6 what's meaning
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
Esta resposta foi útil?
Pontuação 1
E5 error guide please urdu and video
Pontuação 0
Adicionar a sua resposta
Sanjeev Verma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 64
Ao todo: 2,259
