Fingering is disappeared in my settings
Fingerprint sensor is disappeared in my settings
Esta é uma boa pergunta?
@raorajput update your software first. If it still does not show after you upgrade your software, it is possible that your fingerprint sensor has failed and thuise your software can't find it. Check on here for the setup and on here for possible fixes. Different model, same idea. If none of this works, you may need to replace it. Problem is that guides for this are not easily found
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 99
Duração total: 290
