Ir para o conteúdo principal
Headset gamer padrão fabricado pela Razer em 2021. O número do modelo é: RZ04-03800200-R3U1.
My power button got stuck
I dropped it then the power button feels loose, I opened up the device where the button is but can't tell what's wrong with it
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
The switch itself shattered and is in tiny pieces. I need a new switch. What do I do?
por
i have the same problem do you have a result? what can i do?
por
Adicionar um comentário
1 resposta
I had this same problem after I dropped my headset. I took it apart and also saw nothing to seemingly be wrong but I tried to wiggle the little black button and it eventually popped out and the button is no longer stuck and is tactile again.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tyson Ellis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 2,929
