Ir para o conteúdo principal
Modelo A1419 / Final de 2013 / Processador Core i5 de 3,2 & 3,4 GHz ou Core i7 de 3,5 GHz, ID iMac14,2
Swapping cracked display (is it possible?)
Display glass protection on my A1419 27" / EMC 2639 / Late 2013 / with Core i5 3,4GHz is cracked so I want to fix that, but on this particular model that is impossible (glass and display can not be separated). I have an offer to buy a used display for cheap, but I don't know if it would fit. The used display is from a different model:
A1419 27" / Late 2012 / with Core i7 3,4GHz
My iMac has a GTX775M 2GB GPU, while this used display was connected to a GT680MX 2GB GPU.
So, is it possible to swap those two displays?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
This eBay listing says the part is compatible with Apple iMac A1419 2012 27 4K EMC: 2546, For Apple iMac A1419 2013 27 4K EMC: 2639, so I think it would work, but try to confirm with the vendor that it will be supported on your model. Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mikito será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 234
