My phone is not returning on
My phone suddenly get switched off and on it's not returning on
Esta é uma boa pergunta?
@lavanya53310 first check that your phone charger supplies the proper voltage. After that you need to check your charging cable. Check to make sure the pins are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not, it is possible that this is a charging port issue or a bad battery.
You could also follow the Samsung flowchart to do the trouble shooting.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 20
