What other iPhone screen glass only can I use
My screen i is cracked on the edge but no issues using it still except occasional glass bits I. Finger. Can I use the glass from and iPhone 6s to fix
Esta é uma boa pergunta?
@jodiegrover no, you can't. They are all different. I suggest you replace it with a proper assembly. Also, a glass only repair will cost you more than a complete assembly, since you will need extra tools and consumable to get this done. It is also not an easy repair, unless you have plenty of experience to do a glass only repair, Again, I suggest a complete replacement. It is less expensive and straight forward to almost guarantee success if you use the right guides. iPhone 8 LCD and Digitizer Replacement
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 8
