In cpc power supplying is not coming
In cpu power supplying is not working
Esta é uma boa pergunta?
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. Adicionar imagens a uma pergunta já existente
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 34
