Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
412 Perguntas Visualizar todos
Why is my washer leaving clothing soaking and giving me error F25?
My front loading whirlpool washer of 7 years is leaving clothing soaked. Tried to do diagnostic test and it gave me the error code F25. I have tried to plug/unplug it too. The washer does run a full cycle and works just fine.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
please give us your model number
por
It be WFC7500VW
por
My model number is WFC7500VW
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @yeniffer
Here's the tech sheet for the washer.
An F25 is an UI problem see p.4 for how to test the User Interface.
The error code you posted doesn't seem right for the kind of problem you mentioned though.
Esta resposta foi útil?
Pontuação 1
2 comentários:
@jayeff for the whirlpool washers the error F25 usually indicates a possible drive motor tachometer error, which make s a whole lot more sense. Also, I wonder why the error F25 is not listed in the Tech sheet failure codes.....
por
@oldturkey03
It is mentioned only once on p.5 Indication #8
"All display led are turned on.
UI option led will be turned on after options are pushed."
Actuators to be checked = User Interface
Failure code for failure mode = F21, F25
But like you to me it makes no sense, unless the OP is misinterpreting the code?
por
Adicionar a sua resposta
Yen iffer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 49
