Buds pro not charging
Buds are not charging but case is charging
Esta é uma boa pergunta?
My Galaxy Buds Pro case wasn't charging the earbuds. They would only charge when inside the case and the case itself was plugged into a power outlet. The app showed that both the case and the earbuds were fully charged.
I disassembled the case and cleaned the contacts, but it still wouldn't work properly.
I just discovered—by monitoring the app—that if I keep the earbuds inside the case with the lid open, the earbuds start charging while the case's battery level drops. 🎉
I haven't managed to fix the problem permanently yet, but at least I found out that leaving the lid open allows the earbuds to charge. Give this a try if you're looking for a temporary solution.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 157
