O Celular não vibra
O celular não vibra para nada
Esta é uma boa pergunta?
@kauanpvp90 the very first thing you want to do is to make sure that it is turned on.
- Navigate to Settings.
- Go to Sound or Ringtone/Notification
- Check to see if vibrate is turn on.
- Choose always Turn On or similar wording.
Next you want to check if this is caused by any of your others apps. For that you need to start your phone in Safe Mode. Should be like this
1.Turn Off the phone by pressing power.
2.Turn On the phone by pressing power
3.When the logo displays, press Volume down key until the Lock Screen appears.
4.Now You are in Safe Mode
If your phone vibrates in safe mode, you know that it is an app which prevents it from working in regular mode. Install one app after the next until you find the one that caused this.
To check your vibrator motor do this
1.Dial #0# (If it does not work, then use #9998842# ,*#8999*842#,*#7353#)
2. Click the Vibrate
If you get no vibration, it is your vibrator motor that needs to be replaced.
For a few more things to ry, check this video Sorry about the language, just follow the screen instructions.
To work on your phone, use something like this video as your guide.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
@kauanpvp90 a primeira coisa a fazer é certificar-se de que está ativado.
- Navega até às Definições.
- Aceda a Som ou Toque/Notificação
- Verificar se a vibração está activada.
- Escolha sempre Ligar ou uma formulação semelhante.
Em seguida, deve verificar se a vibração é causada por alguma das suas outras aplicações. Para isso, é necessário iniciar o telemóvel no modo de segurança. Deve ser assim
1. desligar o telemóvel premindo o botão de ligar/desligar.
2. ligar o telemóvel premindo o botão de ligar/desligar
3) Quando o logótipo for apresentado, prima a tecla Diminuir volume até aparecer o ecrã de bloqueio.
4. agora está no modo de segurança
Se o telefone vibrar no modo de segurança, sabe que se trata de uma aplicação que o impede de funcionar no modo normal. Instale uma aplicação após a outra até encontrar a que causou o problema.
Para verificar o motor do vibrador, faça o seguinte
1. marca #0# (se não funcionar, usa #9998842# ,*#8999*842#,*#7353#)
2. Clique em Vibrar
Se não houver vibração, é o motor do vibrador que precisa de ser substituído.
Para mais algumas coisas a fazer, consulte este vídeo Desculpe a língua, mas siga as instruções no ecrã.
Para trabalhar no seu telemóvel, utilize algo como este vídeo como guia.
Enquanto trabalhas no teu telemóvel, tira muitas fotografias. Quando terminar, tire essas fotografias e crie um guia para o iFixit. Isso ajudará a próxima pessoa que tiver o mesmo problema que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai ficar agradecida.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 72
