Ir para o conteúdo principal
Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
20 Perguntas Visualizar todos
iPhone restarts every 3 mins approximately after getting splashed on
After device got a little wet it has not stopped rebooting every 3 mins. I have tried a new screen with new prox and new oem battery and still continues the issue. I have provided the panic report below.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi Kevin,
As it turns out, I just recently updated Alisha's (@flannelist) excellent iPhone Kernel Panics Wiki article to include iPhone 13 and 14 information.
iPhone Kernel Panics - iFixit
Going through your log, we can see you've got a SMC PANIC - ASSERTION FAILED error, so looking under that heading we see this error code in your log.
S.sensor array 0 - 6 is 0x0, 0x800, 0x0, 0x0, 0x0, 0x0, 0x0
Here's what error 0x800 means.
  • 0x800 is on the charge port assembly.
Essentially, one of the sensors on the lightning port assembly has failed and can't be read by the processor, so it reboots the phone in an attempt to recover. Of course, once the phone reboots it then goes to check the sensor again in three minutes only to find it can't be read, so it reboots to try and recover. Repeat ad infinitum...
Unfortunately, iFixit hasn't gotten around to creating that guide for the iPhone 13 Pro yet, but there's a Spanish site called Nadie Me Llama Gallina (Nobody Calls Me Chicken) that has just what you need.
Manuals / Apple iPhone 13 Pro / Charging flex
Used in conjunction with the Chrome browser's automatic translation, it is very much usable even if you don't speak Spanish.
That should get you going! The good news is you can put your old parts back in so you don't get those annoying "might not be genuine" messages! To the best of my knowledge there shouldn't be any issue with replacing the charging port; it's not tied to the motherboard like pretty much everything else is.
Esta resposta foi útil?
Pontuação 3
If the iPhone still restarts 2:30Second, change the charging filter
Pontuação 0
1 comentário:
@abdulhmeeda5009 Can you clarify what you mean by the "charging filter"? I'm an electronics engineer and I have no idea what you mean by this.
por
Adicionar a sua resposta
Kevin Hernandez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 823
