Por que não consigo falar com o microfone 1 do Galaxy Flip 3?
Não consigo enviar uma mensagem de audio pelo WhatsApp, pois ela vai sem som. Parece que o microfone 1 não funciona.
Esta é uma boa pergunta?
@luizclaudi86135 you may have already tried this, but first go through the Samsung basics as listed here It is in English but most browsers like Google Chrome translate it pretty good.
Next try a reset as shown on here
Now try this
1-1. 1st mic loopback test
- #0283#
- Select Start : RCV_1stMIC
- Do test : say something into a 1st mic (lower mic).
- Should hear the voice through the RCV (upper spk).
1-2. 2nd mic loopback test
- #0283#
- Select Start : RCV_2ndMIC
- Do test : say something into a 2nd mic (upper mic).
- Should hear the voice through the SPK (lower spk)
Let us know what you find out.
If none of this works, you may want to consider replacing the Sub PBA Daughterboard. That is the board that has the Mic on it. Here is the no voice part of the manual Mic Mute and here is the translated version Mic Mute.en.pt . Hope it is not to bad and will still help you. Use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@luizclaudi86135 já deve ter tentado fazer isto, mas primeiro, consulte as informações básicas da Samsung, conforme indicado aqui Está em inglês, mas a maioria dos browsers, como o Google Chrome, traduzem-no bastante bem.
Em seguida, tente uma reinicialização como mostrado aqui
Agora tente o seguinte
1-1. 1º teste de loopback do microfone
- #0283#
- Selecionar Start : RCV_1stMIC
- Fazer o teste: dizer algo para um 1º microfone (microfone inferior).
- Deverá ouvir a voz através do RCV (spk superior).
1-2. Teste de loopback do 2º microfone
- #0283#
- Selecionar Início : RCV_2ndMIC
- Fazer o teste: dizer algo para um 2º microfone (microfone superior).
- Deverá ouvir a voz através do SPK (lower spk)
Diga-nos o que descobriu.
Se nada disto funcionar, pode querer considerar a substituição da placa filha do Sub PBA. Esta é a placa que tem o microfone. Aqui está a parte sem voz do manual Mic Mute e aqui está a versão traduzida Mic Mute.en.pt. Espero que não seja assim tão mau e que possa ajudar. Utilize algo como este vídeo para trabalhar no seu telemóvel.
Enquanto trabalhas no teu telemóvel, tira muitas fotografias. Quando terminar, tire essas fotografias e crie um guia para o iFixit. Isso ajudará a próxima pessoa que tiver o mesmo problema que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai ficar agradecida.
Reparação é guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 142
