Ir para o conteúdo principal
Released around 2016 to 2018, the Dell Inspiron 15 3568 is a 15-inch laptop targeted at the mainstream laptop market. Most components can be replaced for a repair.
2 Perguntas Visualizar todos
Turning on issues, showing grey screen
After turning on its showing grey screen and cursor nothing else is working except cursor
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@shaury19662 this can happen when your computer can't find the OS. Possibly due to a failed hard drive. Try to enter the BIOS and check if your HDD is still detected. Press the F2 key several times at the Dell logo screen during startup to enter the BIOS. If the BIOS can't find your HDD, I would create a bootable USB drive with a Live version of Linux (I use Puppy Linux). Then set the boot order to USB and boot from that drive. Now use the Linux drive to see if you can access your HDD to at least recover your files. After that you would need to replace the HDD and reinstall your OS.
Of course, all of this might change once you start looking into the troubleshooting. Let us know what you find so we can continue to assist you with this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Shaury será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 190
