Ir para o conteúdo principal
O Samsung Galaxy J1 Nxt (também chamado de J1 mini) é um smartphone Android lançado pela Samsung Electronics em fevereiro de 2016.
How to replace screen
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Ayush Sah,
I was unable to locate any step by step iFixit-style instructions for you to use, but I did run across a YouTube video that will show you what you need to do. This isn't what you'd call a professional level repair by any means, but the basics are all there and will get you through the procedure. It shows you how to replace the front glass digitizer, the LCD itself or both, depending on what exactly is broken on your phone.
SAMSUNG GALAXY J1 MINI (J1 NXT PRIME) TOUCH REPLACMENT SM-J106H - YouTube
As you're working on your phone, take lots of pictures and use those to create your own guide so others can benefit from your experience. It's fun and easy and helps the community.
Create a new Guide - iFixit
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ayush Sah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 566
