Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 12. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 12.
Earpiece and Face ID
  1. I replaced my touchscreen and Face ID is not working. I think I may have damaged the earpiece when transferring it to the new touch screen. I read that you cannot replace the earpiece with a new one and still have Face ID and that if you don’t have the original earpiece transferred over you simply cannot have Face ID ever again. It doesn’t sound true at all… but is it? Why would Apple make a product that would have a major feature banned from use forever because the the original piece that controls it has been broken and replaced? That makes ZERO sense to me.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Baylor,
Unfortunately my colleague @guardian10 is absolutely correct; the flood illuminator incorporated into that earpiece speaker assembly is paired to the phone with a proprietary encryption algorithm that only Apple has access to so they are the only ones who can replace that assembly.
Even worse, should you decide to humble yourself and go to them for help, they won't replace that assembly for you. The closest you can come is to pay them full price for a screen replacement; their screens come with the Face ID components already mounted and part of their replacement process is to reprogram it to your phone.
It is also possible to use their self repair program, but in practice you really don't save all that much over just paying them to do the job after you've bought the part from them and rented their equipment to do the job.
It's especially irksome knowing that in the exact same circumstances other companies like Samsung and Google do make it possible to replace those kind of components, much like how you could never replace the Touch ID home button on older Apple models but you can replace the fingerprint sensor on a Google Pixel phone. So technologically there's no real argument that they're protecting their customers by not allowing aftermarket repairs since other companies have already demonstrated that it's entirely feasible to do so.
And rather than making their phones more repairable, they're actually making them less so; starting with the iPhone XS they started pairing the battery, and with the iPhone 11 you can no longer simply replace the screen without generating warning messages and possible loss of functionality.
Ouch. I've advised my son and daughter-in-law not to get their children phones newer than the iPhone X for the simple fact that I won't be able to repair them if they buy newer models, at least nowhere nearly as cheaply and easily.
Esta resposta foi útil?
Pontuação 2
Sadly, it's true. Apple doesn't want you to repair the device since it doesn't put any money in their pocket.
Face-ID isn't the only feature they disable when you attempt a repair. True Tone is disabled upon display replacement, cameras don't work properly when replaced, and battery health is unreadable after repair. All of this is the reason Apple is loathed among repair enthusiasts.
Pontuação 0
Adicionar a sua resposta
Baylor McCracken será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 105
Ao todo: 2,255
