Ir para o conteúdo principal
Guides and repair information for washing machines produced by GE, an engineering and technology company in the US.
I keep getting E2 error code, how do I reset the machine?
I have a GE portable washing machine, model GNW128PSMWW. I keep receiving error code E2. Any idea what could be causing this? Do I need to reset machine? If so how?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @tammylynn6671
According to the mini manual an E2 error code may indicate a problem with the lid switch part # WH12X26878 or the switch magnet (supplier example to show location of the switch).
If it is the problem search online using the part number only to find suppliers that suit you best.
If the switch and magnet are OK, the manual describes what else to check.
Imagem de Detects when the washing machine lid is properly closed.
Produto
GE Washer Lid Switch - WH12X26878
$7.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
TammyLynn6671 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 67
Ao todo: 3,615
