I drop in water
I drop in water and now my phone is switch
Esta é uma boa pergunta?
Hello there,
You still have a chance to save the phone.
I hope you didn't try to plug in a charger to try to turn in on while charging as this can be fatal if there is inside still some water.
I highly recommend you to:
If you have a luck it will turn on If not the logic/motherboard needs to be inspected under microscope for some short circuits and a professional tech guy who understand microsoldering will need to step ahead and fix it or swap the motherboard from other working phone (like with broken screen).
Good Luck!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 604
I drop my phone in water
por payal doshi
Yes I drop it how can I fix it
por 等やな 葉 歳くださ
Charging port issus
por Chidinso Nnadozie
