Ir para o conteúdo principal
The MSI GF65 Thin 10UE is a gaming laptop equipped with an Intel Core i7-10750H processor and NVIDIA GeForce RTX 3060 GPU. It is designed to handle gaming and demanding multitasking tasks. It comes with upgradable RAM and storage for future upgrades.
Screen gone blank, only a few vertical lines visible
I got this laptop repaired a few months ago. It was working fine, the repair changed pair of fans, thermal system and lcd. After a few months suddenly the screen got blank and only a few vertical lines are visible while turning it on, which eventually goes away. Can someone help fix it
Update (08/06/23)
Here is the attached image
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Here is the attached image [image|3040735]
por
Adicionar um comentário
1 resposta
@abzo connect an external monitor to your laptop. If that displays fine, you know that your LCD is in need of replacement. If it shows the same, the issue could be related to your video circuitry (GPU etc.) and will require some inspection/rework of your motherboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Abzo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 397
