My phone is automatticaly getting switch off and on
My phone is automattically getting switch off and switch on anytime and when it start's the battery get low
Esta é uma boa pergunta?
@pankaj84843 I would suggest that you start off with a new battery. If that behavior continues you will have to check the charging board. Use something like this video as your guide.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
It is a not big problem, is that a setting in your phone turn off this setting to follow few step :
Open setting and open search and type schedule Power on and off .
Click on Schedule Power on and off and turn of this setting.
Finally fixed your problem ☺️
But this phone has the battery issue and service center just done some soldering to the battery and fixed the issue
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 107
Duração total: 1,248
3 comentários
I have changed battery but problem is not solved
por uday chavhan
Battery change
por Neeraj Vishwakarma
@neerajvish93235 is this an answer or a question?
por oldturkey03
