Ir para o conteúdo principal
Repair, disassembly, and troubleshooting information for the fifth iteration of Amazon's Kindle Paperwhite (as part of the 11th generation of Kindle devices). Released October 2021. Identified by model number M2L3EK and M2L4EK.
Why does the “Before You Go” screen pop up part way through a book?
I’ll be part way through a book and the “Before You Go” screen will pop up and I can’t turn the page anymore I have to manually enter the next page number to carry on reading.
It’s fully up to date and I can’t see anything in the settings to fix this.
Can anyone help please?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Chelsea,
Apparently it's an Amazon "feature" like those "Hit Like and Subscribe" comments on YouTube videos. There doesn't appear to be any kind of setting available to turn that off, but I did run across a forum on mobileread.com that seems to be showing a way to eliminate them. Apparently there are files that are triggered by various actions, one of them being when you reach the end of the book. By deleting the file, you eliminate the action and won't get the "Before You Go" message any longer. Here's the page I was referring to.
Disabling "Before you go..." Screen - MobileRead Forums
And just to ensure you can still access this information should that link ever go away, here's the relevant passage you'll want.
It appears the solution is to plug the Kindle into a computer and use the computer to search for files with the text "EndActions" in the name and delete them all. That's supposed to get rid of the problem you're seeing.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Chelsea Michelle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 2,107
