Ir para o conteúdo principal
Smartphone projetado pela Xiaomi na linha Redmi Note.
How to change battery
How to replace back body
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
@imamhusain it is a clip system, you should just be able to snap the cover back on.
Sometimes the clips get broken and you may need to replace the back cover.
Esta resposta foi útil?
Pontuação 3
I wasn't able to find any guides specifically for the Note 4, but there are several available for the 4X. From what I can see on the GSMArena website, the main difference seems to be support for CDMA networks, upgraded Bluetooth and slightly lower cost. I'd suggest following one of those guides, but be prepared as it's always possible there are minor differences so don't let that throw you. Here's a link to the iFixit guide.
Xiaomi Redmi Note 4X Battery Replacement - iFixit Repair Guide
While you're replacing your battery, take lots of pictures and use those to make your own guide for the Note 4 so people who come after you have a set of instructions to follow.
Create a new Guide - iFixit
It's actually pretty easy to do and fun as well!
Pontuação 0
Chang the battery when it swollen
Pontuação 0
Adicionar a sua resposta
Imam husain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 1,011
