Replacement parts in the battery section
My battery contacts got corroded can I replace the springs and positive plates for better connections?
Esta é uma boa pergunta?
Yes you can, sometimes a bit of sandpaper to remove the rust works too if you're unable to replace the whole spring. Alternatively, metal spacers like thin washers or a small coin placed beside the spring before installing the battery can help compress the spring to bypass the rusty portion.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 73
1 comentário
@terrydulong let's see what this looks like. Post a couple of pictures with your question. That way we can see what you see. Adicionar imagens a uma pergunta já existente
por oldturkey03
