Ir para o conteúdo principal
The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
Completely dead Canon 6D - how to troubleshoot (chip level)
Hi,
My 6D died and i assume a broken chip component somewhere. Maybe was a bit too long in the sun. Does anybody has some insight totroubleshoot a 6D on the chip level, or
  1. Check the power distribution board?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@davidlamafan I would check for power first. If there is any possibility that it may have gotten too hot, start with a new battery. If that does not work, Time to disassemble and to take a closer look at tall power board. You may be lucky and find a fuse on that board. Use these guides to work on your camera Canon EOS 6D OF course, your can also use videos [https://www.youtube.com/watch?v=tUl9cV5G... |like this} as a guide. The other 2 videos in this "series" are also posted on YT.
Post some good (well focused and large enough images) of your boards etc. That way we can see what you see.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
davidlamafan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 248
