Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
Screen partially black, which part should I focus to repair
Please see attached photo and video, which might give an idea for those who experienced similar situation.
The black area also shows ghosting, and without an impact, rarely it goes away by itself after some time of usage. I am using club 3d cac-1510a (non hdcp model) and the black region occurs also without the adapter (i.e. with a basic dvi to hdmi adapter).
Which card should I focus to replace or repair, what might be causing this issue? Any ideas would be more than welcome.
Güncelle (07/29/23)
Let me try, thank you very much.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Sorry your image is not fully posted! Create a fresh answer then grab the image from the toolbox posting it’s ID then save the Answer as an update.
por
Adicionar um comentário
1 resposta
Solução escolhida
@umurguldiren you have a failed panel. The driver board, which is attached to your panel and can not be changed, is what is causing this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Umur Guldiren será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 77
