Ir para o conteúdo principal
Repair guides and support for your Toshiba TV.
20 Perguntas Visualizar todos
My tv has just randomly stopped working
So I don’t get it I have a Toshiba tv I was using today while playing Xbox I decided to take a break so I shut down my console and television while I got some fresh air. I got home and tried turning on my tv but nothing happens now… I’m assuming it’s broken somehow but I really hope it isn’t. I’ve tried unplugging it for 60 seconds and holding power button for 30 then plug back in but that didn’t work so I don’t know what else to do :(
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@lubu what exact model number is your TV?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like a good first step, but if it didn’t help, there’s a whole page of troubleshooting steps for TVs that don’t power on. Although a couple things I would make note of before you dig too deep to make sure you’re in the right neighborhood.
The page mentions it, but be sure your TV is plugged directly into a good power source (outlet, surge protector, etc…).
Check and make sure you actually have no power. Are any lights coming on? Do you get any sounds? I would test with a video input you know it will try to use (your Xbox is a good bet if that’s what you last used). If that’s the case you‘re getting power, but not video.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Lu Bu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 184
