Replacing DVD writer to SSD
How i can change the DVD writer to SSD sloat using caddy method, and which size of caddy are correct to use SSD.
Esta é uma boa pergunta?
The DELL Inspiron 15 DVD is 9.5 mm thick and most standard SATA SSD's are 7mm.
You will need a Universal 9.5mm SATA 2nd HDD/SSD Hard Drive Caddy For CD/DVD-ROM Optical Bay.
The SSD may need a little foam spacer.
Here is a video on how to remove the DVD
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 616
