Ir para o conteúdo principal
O Onkyo TX-800 é um receiver transistorizado que foi lançado em 1989 e descontinuado em 2002.
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
Esta é uma boa pergunta?
Pontuação -1
3 comentários
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
por
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
por
Laura, thank you for accepting my answer. Best of luck to you....:)
por
Adicionar um comentário
1 resposta
Solução escolhida
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Laura será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 4,088
