Ir para o conteúdo principal
A portable AM/FM tuning speaker with auxiliary connection for iPod, iPhone, CD player etc. Released in 2002.
What kind of screws?
Does anyone know what kind if screws the PAL uses? I stripped them opening it up and want to replace.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
They are most likely metric. Ace Hardware usually carries an assortment of metric screws. Take it in and see if you can find the right one.
Esta resposta foi útil?
Pontuação 0
@julianboilen those look like #6 or #8 x3/4 rolling screws for plastics. You could measure the diameter and length with a pair of calipers or similar. #6 is 9/64" and #8 is 5/32" in diameter. Do not use wood screws from a hardware store since those are different. I am sure that the needed screws are readily available online.
Pontuação 0
1 comentário:
Hi, did you find out which screw you needed for the Tivolio Ipal radio ? I am looking to get screws as I have misplaced those that hold in the back plate for the battery compartment.
por
Adicionar a sua resposta
Julian Boilen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 193
