Ir para o conteúdo principal
Repair and troubleshooting information for the HP EliteBook 840 G6, an HP laptop part of the HP EliteBook series. Released in May 2019.
19 Perguntas Visualizar todos
Laptop power blinks white and orange, not turning on.
I have a new laptop, worked fine and then it was dropped. And now it no longer turns on. The power button would light up along with the caps lock light then turn off. I plugged in the charger and it shows no life. So i took the battery out and put the power adapter in and now the indicator light blinks white, amber, and then stays amber. Sometimes the keyboard lights will come on and sometimes it will not but the screen will never come on. Might I mention that while putting the battery connector back in, a light on the board would flash white and go away. Same with the power adapter. I'm not sure what to make of it, I contacted HP Support and they were no help.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Check and count how many times the caps lock blink?
Then I will show you the error table.
por
Just once. It comes on for a few seconds then goes off.
por
Adicionar um comentário
1 resposta
Hello @greykingdom
How many times does the caps lock light flash? I know that if it flashes three times, it is most likely that the RAM is not seated correctly. Just find the ram, remove it by pushing the metal clips away from the sides of the RAM, and it should pop out. Put the RAM back in, and the laptop may be functional.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Grey Kingdom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 1,981
