Ir para o conteúdo principal
Released in 2021, this lineup of the F15's features an Intel i5 or i7 processor, NVIDIA GeForce RTX GPU, and 15.6 inch 1080p display. These laptops have a sleek design and hardware optimized for performance-driven gaming at a lower price level.
10 Perguntas Visualizar todos
Window button not working and battery drains faster
Hi there
I don't know why but my window button suddenly stopped working and i just don't understand why because I don't use laptop that oftenly and i just wanna know is it a software issue or a hardware issue and also my battery drains like hell from 100 to 10% in just 2 hours I don't know why, for this i also cleaned up my laptop and install the os and i have not installed any application which drains battery still on just browsing it drains crazily and yeah my window button stopped working after 1 week of installing os. Please guide me for to resolve this issue it would be a great help. What i should do for this.
Asus TUF Gaming F15 fx506lhb
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @astrangeguy
Here's a link that may help with the Windows key problem.
Regarding the battery problem, create a battery report to check the condition of the battery.
Once you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same value. If the Full Charge Capacity value is <40% of the Design Capacity value, you may want to consider replacing the battery.
Try starting the laptop in safe mode with networking and check how long the battery lasts. The display will look different because only basic Windows drivers are loaded and not hardware specific ones, but the idea is to check battery performance. Note that this will only work with a Ethernet cable connection to the internet and not WiFi
If the battery is OK as per the battery report and also when in safe mode, check how many programs are being loaded on Startup. Not all programs loaded on Startup are necessary for correct operation.
Sometimes 3rd party programs installed by you appear in Startup so that they open faster when you want to use them. If however you don't use them that often they are still preloaded so to speak and are using up hardware resources unnecessarily, causing the laptop to work harder than it should. You can disable the program from Startup by right click on the program in Startup and click on disable then restart the laptop. This doesn't affect how the program works. It will still start, open OK etc when clicking on the desktop icon or in the program menus. It just takes slightly longer to open that's all.
Some programs are necessary for correct operation however. If you don't know what the program is used for Google the name to find out. Also only disable one at a time and check. If it causes problems when doing this simply enable them the same way as you disabled them.
Esta resposta foi útil?
Pontuação 0
4 comentários:
The windows button not working part sounds like an issue we have at my job a lot where profiles corrupt themselves, breaking the start menu and causing insanely high CPU usage, might be something to look into-
por
@ezzgen
Have you checked why this is happening where you work, e.g. viruses, ram or ssd/hdd problem, frequent power outages perhaps etc?
por
@jayeff It was a windows update that borked it, like the defender update a while back that nuked users icons... microsoft just isn't great at making their own software-
por
@ezzgen
Fair enough.
Although in this case the OP stated that they'd reinstalled the OS so presumably this may not be the reason
por
Adicionar a sua resposta
A Strange guy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 64
