Ir para o conteúdo principal
O Galaxy A20s é um smartphone Android de nível médio lançado pela Samsung em setembro de 2019. A identificação é possível por meio dos modelos número SM-2070, SM-207F/DS e SM-207M/DS.
screen power not working
After falling from the hand, the screen of the phone turned off and did not turn on
Esta é uma boa pergunta?
Pontuação 0
1 comentário
is the screen cracked?
is the phone making sound?
is it recongized by a pc?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@nazmulisla38051 could be a broken LCD, a loose connector or even some board damage. It all depends on how hard it fell and the comment by @timtomissus would shed more light onto that. So let us know about those details. Use something like this video to remove the LCD and it'll allow you to inspect your connector. Make sure it is fully seated and that the LCD flex is not torn etc. If all of that checks out ok, I would suggest a LCD screen replacement.
If you need to go to a boardlevel repair, check the Samsung Flowsheet
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Nazmul Islam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 14
Ao todo: 176
